Jree Member Jan 31, 2020 44 31 San Diego Sep 23, 2020 #1 Sep 23, 2020 #1 Has anyone heard anything similar?
Wennfred Active Member Supporting Member Apr 4, 2019 3,162 2,229 San Diego Sep 23, 2020 #2 Sep 23, 2020 #2 No but it sounds big enough to detect, have someone else drive the car while you sit in the passenger seat to look for it. Fred
Jree Member Jan 31, 2020 44 31 San Diego Sep 23, 2020 #3 Sep 23, 2020 #3 Tried that. Can’t find where it’s coming from. I’m seriously disappointed at the service center’s ability to fix this issue.
Wennfred Active Member Supporting Member Apr 4, 2019 3,162 2,229 San Diego Sep 23, 2020 #4 Sep 23, 2020 #4 I mean it’s very loud, if it’s coming from the door, you may have to pull the door panel to look, videos on YouTube on how this is done. Check the front right wheel for looseness. Something is banging under the wheel well. Fred
Jree Member Jan 31, 2020 44 31 San Diego Sep 23, 2020 #5 Sep 23, 2020 #5 It's not the front right wheel since the front left wheel is the wheel going over bumps. Also, I took off the door panel and taped down everything.
Candleflame Active Member Mar 9, 2015 4,582 2,618 QLD, Australia Sep 24, 2020 #6 Sep 24, 2020 #6 service appointment. Sounds to me like some bolts on your axle/tire are too long and touching something. Have you changed wheels or had brakes/parking brake serviced?
S Sam1 Active Member Sep 11, 2019 2,621 2,664 NV Sep 24, 2020 #7 Sep 24, 2020 #7 That doesn't sound like a door problem, that sounds like a mechanical problem because of the loudness and timing of it
AZAV8R Member Aug 29, 2020 296 301 Arizona Sep 24, 2020 #8 Sep 24, 2020 #8 Seems like is something mechanical, based on the cyclic nature of the sound.
Mattopotamus Member Jun 7, 2020 406 331 Atlanta Sep 24, 2020 #9 Sep 24, 2020 #9 I am with others, this does not sound like a door rattle. Definitely schedule service.
