NXN-P3D
Better ask the shop to do it for you.How do you shave them off? I'm not that handy lol
Looks pretty decent. Does the rear poke out a little bit from the fender or it fits perfectly? The front is good?I hereby confirm that the Bonoss 20mm spacers fit well on the 2021 TM3P and 20" OEM Überturbine wheels.
The front is fitted with no-name universal 5mm spacers from Amazon.
The car is lowered with springs from T-Sportline. 1" front and 1.2" rear.
Looks good!I hereby confirm that the Bonoss 20mm spacers fit well on the 2021 TM3P and 20" OEM Überturbine wheels.
Just to update. My RHD M3P is on Uberturbine with H&R 1.2" drop. I have put 5mm front and 18mm rear from Bloxsport. They look just great although it would be more perfect with 10mm front and 15-16mm rear.Looks pretty decent. Does the rear poke out a little bit from the fender or it fits perfectly? The front is good?
I am ordering 5mm same for the front and 18mm for the rear. Just wondering if I should change to 20mm.
Still available?With that said.... I've got a pair of slightly used 15mm BLOX if anyone's interested, PM me!
How bad does it rub? Just the rears?Just to update. My RHD M3P is on Uberturbine with H&R 1.2" drop. I have put 5mm front and 18mm rear from Bloxsport. They look just great although it would be more perfect with 10mm front and 15-16mm rear.
Now 5mm front looks a bit too thin from the fender, and 18mm rear pokes out 1-2mm from the fender. No rubbing issue until now.
No rubbing problem at all. Just poke out 1-2mm from the fender only in the rear. But that's fine for meHow bad does it rub? Just the rears?
I just ordered 15mm front and 20mm rear bloxsport now bonoss for my 21 model3 performance with Martian wheels. My plan is if the Martian wheels don’t have a large enough cavity I will trim the factory front studs. They sent me this response.
Two questions:I hereby confirm that the Bonoss 20mm spacers fit well on the 2021 TM3P and 20" OEM Überturbine wheels.
Thanks.Just FYI. I have a 2021 Model 3 Performance and the 15mm BLOXSPORT's fit. I tossed their 15mm on the front and 20mm on the rear.
That being said, 15mm on the front was too much. I need to get some hubcentric 5mm spacers for the front. I think 8mm would be perfect, but that's not going to work without pressing in some custom length studs and I don't feel like messing with ti that much.
I have Martian wheels that sit in a little further than the uberturbines because they are 8.5” wide and uberturbines are 9”, so from my measurements 15 should be good.Just FYI. I have a 2021 Model 3 Performance and the 15mm BLOXSPORT's fit. I tossed their 15mm on the front and 20mm on the rear.
when will you have the black 14mm spacers in stock again?Either will work for the rear. Some people like to stay consistent with brands, color, etc.
That's why we have options
Danny
If it's a proper bolted joint, you should never need to retorque. You'd only lose torque if you have embedment or a joint slip. Neither should ever happen if installed correctly.OCD alert. I assume you guys periodically retorque the spacer lug nuts? I would think that’s a pain since you have to remove the wheel to do so, so I was thinking to get longer lugs and use slip ons. Thoughts?
Not being argumentative, but I’ve always retorqued my wheels every couple of months or so, and also we would retorque the wheels on my racecar after every session, as well as “nut and bolt” the entire car after every race weekend. Agreed that not every nut or bolt would end up requiring retorqueing but at least some would. How do we install nuts and bolts correctly so as not to require retorqueing ever (serious question)?If it's a proper bolted joint, you should never need to retorque. You'd only lose torque if you have embedment or a joint slip. Neither should ever happen if installed correctly.
