P3D-R
Closed
The H&R won't work with your wheels. The lug opening needs to be about 18mm in ID which is very unique to the OEM wheels. The shank for the H&R lugnut has about a 17mm OD iirc. Please see picture I took below.Can you explain how these work? Model plus says they can only be used on OEM wheels but I’m confused. Do these basically extend the factory lugs so that you can have enough thread length? Are they hard to install?
In reference to the spacer issue you would have with both Rohana, Momo, Forgestar, and ADV.1 is due to the diameter of the wheel mating surface or wheel pad if I understand you correctly. I also discovered this when trying to use spacers on some Forgestar and Momo wheels I have. Please reference the Aspira spacer install guide here. They have done a great job in illustrating the measurements you need to make, aside from pocket depth, to ensure that the wheels are compatible with studded spacers.
![www.aspiraautodesign.com](https://cdn.shopify.com/s/files/1/0261/2281/3543/files/aspira-forged-_small_centered.png?height=628&pad_color=ffffff&v=1613513820&width=1200)
Aspira Auto design Spacer Install guide
Aspira Auto design Spacer Install guide This tutorial will give you a basic step-by-step guide to help install our spacers onto your model 3/Y. The general procedures follow those of a simple tire change Tools: 1. 21mm socket for OEM lugnuts 2. 10mm socket to remove oem rotor retaining bolts 3...
