I had a fender liner rattle on my car that sounded pretty similar to that. If you sit inside the car and have someone tap around under the fender liner you might be able to replicate it. On my car the rattle was VERY noticeable at certain higher speeds. I was able to get the service guys to fix it.Does it sound like this by any chance? https://photos.app.goo.gl/gmaCZfiDW4DDNmVf8
By fender liner do you mean the front wheel well liners? What was the fix for this exactly? I’ve looked for missing push pins or w/e and didn’t really see any that might be causing it some movementI had a fender liner rattle on my car that sounded pretty similar to that. If you sit inside the car and have someone tap around under the fender liner you might be able to replicate it. On my car the rattle was VERY noticeable at certain higher speeds. I was able to get the service guys to fix it.
Mine was not missing and clips. There was just some spot that it was hitting. I think the service guy stuck some foam in one spot and bent a tab.By fender liner do you mean the front wheel well liners? What was the fix for this exactly? I’ve looked for missing push pins or w/e and didn’t really see any that might be causing it some movement
My Model 3 with 2000 miles has developed a rattle when I drive on non smooth roads. The noise comes from under the front dashboard left of the steering wheel. Anyone else notice this?
Honestly it is hard to say what exactly that fixed it for me. Your issue may be a little different seeing as you can stop the noise by placing youR hand on the trim.My car sounds exactly like that, how did you fix it ... I posted a thread this morning but hadn't seen this thread, my post is here with video and photos.
New Model 3 - Rattle noises
link to video here: Dropbox - SourceofVibration.mov - Simplify your life
