Jumps to 32A at start, then drops to 16A, then just stops all together after about 10/15 minutes
Similar to @Fullerene , your video shows a full 5% drop in voltage when applying the 32A load. However, unlike his case the supply voltage is quite healthy to start with and the bottom voltage (228V) is not out of spec for a UK supply. So this one does look like a problem more local to you - either in the chargepoint, its wiring, or specifically your supply cable (whereas @Fullerene 's problem seems to be a problem with the whole neighbourhood supply rather than just his).
