Model 3 won't wake up from app OR in the car
jjrandorin
Nov 28, 2018
8,088
8,959
Riverside Co. CA
I've never owned a car which only has a 15" laptop screen to provide feedback and without which the car is undrivable (pedals and gear stalk dead and phone app was hanging).
A better analogy is "have you never had to hold down the power button to hard reset your phone or Windows laptop?". The answer, of course, is yes but very, very occasionally. Maybe twice in 25 years I've had to reinstall windows due to corruption, but not for a long time.
Obviously having to double scroll wheel reboot the car occasionally isn't more than an inconvenience. However it does indicate something is wrong. Should the double scroll wheel reboot fail to work, this could lead to major inconvenience. And the car is only 3 weeks old which doesn't instill confidence.
I am more than happy to beta test features for tesla as long as glitches are only minor inconvenience.
Cheers.
The team I manage supports windows and mac devices as well as phones, and lets just say they break a lot more than you have experienced, and have to be rebooted, in general, way more than you have experienced. Thats phones though, not a car.
I have owned my model 3 for a bit over two years now (2 years and a couple months) and have experienced a situation where the screen went dark, and there was no feedback, 1 time (was in the garage at the time).
Because the car doesnt get "shut down" that often (it goes to sleep) and I feel ALL computers need to be rebooted occasionally (obviously servers much less than regular consumer computers, but...) I shut my model 3 down using the power off feature after every firmware update. That means it gets shut down, on average, every 3-5 weeks or so.
I dont think you are going to have some systemic problem that renders the screen inoperable, and if you do, it would need a service appointment. Needing or wanting to reboot it using the thumbwheels, likely a bit more often but its not "common" for the car to have an inoperable screen.
Reactions: dmurphy
Peteski
3,524
2,280
UK, Milton Keynes
3 years experience with a Model X has taught me that the odd re-boot is required. Earlier software versions were worse for freeze ups, but never had a situation where a re-boot has failed to get it going.
Only had our M3 for a couple of weeks and so far it has behaved itself, although it did spontaneously re-boot itself in the garage the other day. I didn’t even give it a second thought.
Swordtail
23
7
UK
Yes, I agree about the reboots, I think I'll follow your lead on this one, cheers. It'll make me feel better if nothing else!
Gasaraki
1,514
1,004
Syracuse, NY
I've not driven my model 3 for a couple of days but it has been plugged in the whole time. This morning the app was hanging with the "waking up..." message. I went to the car which did open with the bluetooth phone key but the screen would not wake up. I managed to reboot it by holding down the two scroll wheels.
It is a bit disconcerting this happened, especially as the car is less than a month old. There hadn't been a software update as far as I can tell.
Should I worry about this and report it?
Cheers.
No.
Peteski
3,524
2,280
UK, Milton Keynes
I would only worry about it if you keep having this issue repeatedly. For me it’s typically something that happens maybe 2 or 3 times a year. Usually when I’m in a hurry!
Swordtail
23
7
UK
The Tesla advisor responded with:
"The screen going black is something which has happened to me before and can be quite worrying. In essence as the screen is very much like a standardised PC/Mac or tablet device it has a cache. Cache memory is a chip-based computer component that makes retrieving data from the computer's memory more efficient. It acts as a temporary storage area that the computer's processor can retrieve data from easily. This temporary storage area, known as a cache, is more readily available to the processor than the computer's main memory source; however that can fill and needs to be cleared.
I’m not sure if you have ever been working on a PC and have had the message ‘Windows has detected an issue and had to restart’ when your machine does that it is basically clearing the cache as your car has done. You can also manually perform this action whilst in park; press and hold the brake pedal and hold in the two scroll wheels on either side for approx. 20 seconds, you will then see a Tesla symbol on the main screen and you can let go of the brake and scroll wheels. However with that being said if you can where possible keep a log of date and time of these screen outages I am more than happy to investigate this for you"
I'm not completely convinced it's a cache overload issue as you'd hope (!) a modern computer would manage its cache a little better rather than freeze and require a hard reboot, but I'm not going to worry about it unless it starts to happen on a regular basis.
AZAV8R
95
88
Arizona
"You can also manually perform this action whilst in park; press and hold the brake pedal and hold in the two scroll wheels on either side for approx. 20 seconds, you will then see a Tesla symbol on the main screen and you can let go of the brake and scroll wheels."
I have read that holding the brake pedal does nothing. Did I miss something?
jjrandorin
Nov 28, 2018
8,088
8,959
Riverside Co. CA
Thats my understanding as well (that depressing the brake pedal does nothing additional).
stopcrazypp
10,000
4,918
Being in software engineering, I don't really buy the "cache" argument that much. The blue screen he mentioned in windows is not typically from cache issues. However, it is true that if there is a memory leak in an application (basically the application keeps taking up memory, but never releases it), it will keeping using up memory until the computer becomes unresponsive, freezes or crashes. In such a case, a reboot would help fix things.
The core problem is some bug in the software, and you would need to take note of the day and time the freeze occurred, then they can look back at the logs to determine which application was causing the issue (and perhaps do further diagnosis from there). Absent of that I don't think they have personnel with the free time to comb through logs without an idea where to look for.
Reactions: GtiMart
stopcrazypp
10,000
4,918
The latest manual doesn't mention the brake pedal either (at least the latest version), only the two scroll wheels) Was there perhaps a change from a previous version or why would it be mentioned so frequently?
Swordtail
23
7
UK
I certainly didn't have my foot on the brake when I held down the scroll wheels, so I just ignored that! Hopefully the car isn't prone to launching itself into a wall when rebooted :eek:
Although I'm an ex-mainframe programmer and no Windows expert, this makes much more sense to me. When I contacted Tesla I mentioned I didn't know if they'd automatically get an error log or something for this. I think I was fobbed off a bit with the cache explanation but as long as whatever bug caused the issue isn't a very regular occurrence, I don't expect it matters. The nature of Tesla's software update strategy is going to be prone to bugs, but as long as they don't stop me being able to drive the car, I can put up with them knowing I'm getting new features more quickly and they'll likely be fixed pretty quickly.
