Hey all-
I have been driving my model S frequently since fixing it up (see previous posts on battery and drive unit fiascos). Everything has been great until today, when I attempted to use a supercharger (a different location than what I typically use). I plugged the charger in and everything worked initially, however the miles/hr charge rate seemed high (it went to 350 and then dropped slowly), and after several seconds I got errors for "unable to charge" and "remove charger and try again" and "service required." I was unable to charge, the light at the charge port was red and the lock tab was up, and I got a few errors codes when I checked in service move (CHG_w062_FCPosCntrWelded and CHG_f065_FCCntrRationalitycheck). I am still able to drive, however I can no longer open the charge door. I tried a soft reset and pulling the 12v battery and fireman's loop to hard reset the car to see if it would fix things, but it did not work.
I am trying to troubleshoot now and figure out what happened. I suspect this different supercharger dumped too much electricity into the charge box and damaged the charging unit, but I am not sure. Is it possible that a fuse was blown on the inside and needs to be changed? I am posting this because I have seen little to no information on these issues. As with previous threads, I will update on this issue and what the solution ultimately is. Where are the fast charge contactors (rear hv junction box?), and how can I check if they are welded?
