Just recently – within the past couple of weeks – the Charge Time Remaining calculation when charging at home is off by nearly a factor of 2. This problem may have been coincident with my last firmware update. I have a 2013 S 85 with firmware version 2019.24.4. Power level at charger is fine; and in fact, this incorrect calculation does not occur on my 2016 X using the same charging equipment.
For example, when I expect charging time to be about 15 - 20 minutes or so, the estimated charge time is displayed as 55 minutes. The car correctly stops charging at the selected battery level (I typically charge to 80%). Just before it completes charging, the estimated charge time remaining shows to be about 20 or 30 minutes; then the car completes charging and “Charge Completed” is shown (as it should be).
Anyone else noticing this error in the Charge Time Remaining calculation? Note: I’ve not checked this at a supercharger.
