I'd like to HAVE THE ABILITY TO do "track like" things with it.After having my X plaid for 2 months now I can say, who would track this thing? I just can't envision it, it's not that kind of vehicle IMHO.
Curious as to what your take is on why you wouldn't consider tracking it?After having my X plaid for 2 months now I can say, who would track this thing? I just can't envision it, it's not that kind of vehicle IMHO.
When have you actually experienced a need for "better brakes"?better brakes
It's as much want as it is need. My wife's 2022 MYP has better (more confidence inspiring, better pedal feel) brakes on it than my MXP does - and I can confidently say that having logged ample seat time in both vehicles.When have you actually experienced a need for "better brakes"?
"Easily overpower"It's as much want as it is need. My wife's 2022 MYP has better (more confidence inspiring, better pedal feel) brakes on it than my MXP does - and I can confidently say that having logged ample seat time in both vehicles.
Any time that I find myself needing to get into the brake pedal, I always compare the experience to our MYP and I always come away wanting the MXP to be better.
I'd rather have the better brakes and never truly need them than ride around in a vehicle that can easily overpower its own (as it is configured stock at this time).
I don't feel like I ever have overpowered the brakes (per your questions above) and as such I've not seen the warning light and I wasnt on any track."Easily overpower"
What were the conditions where you found that you "easily" overpowered your brakes?
How many times have you triggered the conservative brake temp warning light?
And how often after the warning light did you actually experience any brake fade? And if so, what race track were you on?
On my 20" 23MXP, is there a recommended rim width over stock, or just increase tires? Do they fit? 265/45 Front, 275/45 Rear.It is a 6000 pound family hauler- 1000hp or not- it will not stop fast / especially more than once in quick succession. Said that- brakes on the MXP are adequate. No- it will not stop like a track car or even like a plebeian modern car. For that you need $20k in bigger (carbon) rotors, 8 piston calipers and matched pads, brake line cooler and proper fluid in the front. Rear is irrelevant. But again- 6000 pounds and quick braking regardless of the braking setup is an oxymoron.
One time emergency braking in the MXP is about the best you can expect. Proven by braking tests against other sporty SUVs that are about 500 pounds lighter.
Lastly- the MXP is undertired both front and back- a full on panic stop on dry surface will activate (just barely) the ABS which means that unless you run wider fronts/ slicks in dry weather the braking is tire and not brake system limited so improving the brakes will not result in shorter braking distance- just better feel and repeatability. But see my first sentence about the family hauler.
