Is there a way to re-calibrate or reset the trunk on the MX? For the past 2 months the trunk will not close all the way when you press the button on the back or use the fob. It will close most of the way and you can hear the motor running to pull the door into the seal but the trunk but it just sits there. If you pull up on the back end it has latched but still has movement and the center screen says it is still open. Kind of like on an ICE car where you can gently close a door to engage the latch but not push in all the way.
Anyway for it to fully close I need to manually pull the trunk down from full open to make sure it closes completely which it doesn't seem to like, kind of resists me as I push it. Each time I go to put in a call to the service center it starts working via the button again. Then a week or so later it stops again. Is there anything I can do/try on my own to remedy this before I do take it in to the service center? The service center is over 100 miles from me so its not the most convenient to take in for a smaller issue like this.
