Depends on the 'trailer'. Camper of a given size or small flatbed for getting wood from Lowes.What do I need to get to be able to tow a trailer?
As mentioned above, it depends on what you're trying to tow. Note that the Bosal hitch adapter in the box has a label on it that defines some stringent limits on offsets, so make sure whatever ball mount you get stays within those offsets.I got the wife a 2020 Model X.
It comes with a tow-hitch thing in a foam box/bag in the trunk...
It does not come with a tow-ball.
The type of trailer you are going to tow will determine what type of ball you need and whether or not you also need to install a brake controller in your car. California law requires trailers over 1,500 lbs gross weight to have their own brakes. See DMV allows customers to avoid coming to a DMV office for 60 days - California DMVWhat do I need to get to be able to tow a trailer?
What are you towing with that hitch?If you want the best hitch that absorbs some shocks and bumps, I personally am using a
GEN-Y hitch rated to 7,000 lb
Overwhelmed with questions and information...Where's @SoCalNick ?
Nothing fancy just a Neo Cargo trailer, filled with commercial ride on floor scrubbers. Easy to ride them up and down the ramp. Just strap the wheels down to the E-tracks and the Gen-Y hitch helps with MX air suspension not taking such a beating, its like having a small car in there.What are you towing with that hitch?
I just want to point out that @Soey22 is towing with a Model X (based on his signature) which is rated for up to 5K lbs with the 20” wheels. I thought there might be some confusion because he is using a hitch ball product called the “GEN-Y” and this is a Model Y forum.I personally am using a
GEN-Y hitch rated to 7,000 lb...Both Trailer & Hitch are rated at 7k lbs GVWR but I don’t tow more than 4k lbs which I find is an extremely comfortable ride.
The Model Y hitch is rated to 3.5K lbs.
My apologies. Of course you are right. I got confused; too much switching between towing threads in the X and Y forums!I had to double check, it's the Model X forum!
