Thank you. I'd like to hear from the people who went through the 12,500 mile check-up. What was done, what was found.
We had the 12,000 mile checkup this past Friday. Quoting the relevant content from the service invoice:
Replaced the wiper blades, cabin filter and key fob batteries.
Inspected the brake and cooling system (including fluid levels and condition). Inspected the tires (did not rotate on this visit).
Check the operation of the mechanical and electrical systems on the vehicle. Check operation and lubricated all the closures on the vehical.
Set the adjustable aligment angles to spec (printout in the car).
BLADE ASY-WIPER RH (6005947) 1.00
BLADE ASY-WIPER LH (6005948) 1.00
BATTERY LITHIUM COIN 3V 20MM 2.00
(2006794)
FILTER - PARTICULATE (1007479-00-C) 1.00
Perform vehicle wash
Check and Adjust Tire Pressure - CA MANDATE Set all tire pressures to 42psi.
Concern: Steering Notchy Feel or Clicking Sound
Cause: Noted a creaking from the front end when turring.
Correction: Add Shim to Steering Mount Bolt and Retorque Subframe Bolts
Installed the shim on the right side of the steering rack and torqued the subrame boltes per SB 13-32-001.
Part Qty
Washer, Shim 28x16x0.5 (1024933-00-A) 1.00
Concern: B-Pillar Seat Belt Noise
Cause: Inspected the B-pillar D rings and no slick tape was present. Correction: Apply Tape to B-Pillar Bezel
Installed the slick tape to the B-pillar D rings per SB 13-20-003.
