My spare connector is on the fritz. Dangit.
Discussion in 'Supercharging & Charging Infrastructure' started by zack, Oct 11, 2011.
  1. zack
    zack Member
    Minneapolis, MN
    I just tried to plug my car in at home after a long road-trip and discovered that my spare connector won't light up green anymore. It occasionally blinks once or twice if I wiggle it in the socket but it won't charge the car at all. Bummer! The plug is labeled with model number from North Shore Safety that doesn't fully match anything on their website, so I wrote to them (as well as Tesla) to see if repair parts are available. I wonder if the current limit for the GFI was custom-adjusted for Tesla? I know that the GFI current sensitivity allows higher ground-current leakage for cars than indoor equipment. Does anybody know if the plug circuitry is custom-designed for Tesla?
  2. Sparrow
    Sparrow S105/ Roadster 189
    Marietta, GA
    You reminded me that mine died last week too. It was working charging the car and a few hours later I came out and it had died. I was just going to go to Home Depot and put a regular plug on it, but I had forgotten about it until now.
  3. tdelta1000
    tdelta1000 Active Member
    South Florida
    Z, what has TM said about your troubles, if anything thus far?
  4. zack
    zack Member
    Minneapolis, MN
    Tesla has fixed each problem as it's occurred... kudos to them.
    The first night I brought my car home, someone unplugged my spare connector and left it on the ground in my apartment's parking garage, and then someone else inadvertently drove over it, crunching part of the case. I have a feeling that's why it's failing now. It worked for 7 months after being abused but has finally kicked the bucket.
  5. W.Petefish
    W.Petefish Active Member
    Got any photos of the unit?
  6. zack
    zack Member
    Minneapolis, MN
    It's got a scuff on one side and the case is cracked near where the yellow cord enters, but otherwise it doesn't show any major physical symptoms. I opened it and the circuit board and components visually show no signs of damage.
  7. W.Petefish
    I think the signaling circuitry is in the metal housing itself.
    As discussed in the GFCI problems thread in Roadster>Technical Discussion, you can remove the GFCI with three screws and put a new one on.
  8. zack
    zack Member
    Minneapolis, MN
    The only thing I'm concerned about is whether Tesla made any circuit modifications to the plastic GFI unit to allow higher ground leakage than it was originally designed for. It's my understanding that devices like electric cars are allowed a higher ground-fault leakage current before cutout (which is why wall-mounted GFIs will fight with our chargers for the Tesla sometimes).
  9. zack
    zack Member
    Minneapolis, MN
    Replacement part PGFP-A11-220 Rainproof ELCI plug is on it's way from GFCI / ELCI - Ground Fault Circuit Interrupters and should arrive in a week or less. $56.90. I also picked up a heavy-duty 120VAC/15A plug and socket to put in-line before the GFI plug so I can eliminate it when plugging into a GFI-equipped socket.
  10. zack
    zack Member
    Minneapolis, MN
  11. beakmeister
    beakmeister Member
    Thank you Zack. The North Shore Safety: PGFP-A11 is still available 30$ with shipping to California. There are slight differences in layout (the wires are in a different order, but color coding is the same. The weatherproofing is different). The roadster is now charging at 110V.
