NASA Funding Rotating Detonation Rocket Engine work (Non-SpaceX)
I'm not convinced this engine will work at scale needed for propulsion. I'm thinking about the direction of the force, the energy needs to change direction to go in a circle and the camber wall have to apply an equal force to change the direction. The useful propulsion force could be reduced? Perhaps I need to study the research paper more.
Not a test flight of the engine, only of a drone that they want to use. So they were essentially testing infrastructure.
Duggleby said Venus is considering a couple of options for its next test. If it can identify a range for supersonic flight, it may attach its existing rotating detonation engine to the 8-foot drone. The current engine, which has a firing ring 4 inches in diameter, produces about 1,200 pounds of thrust. Such a test flight, if Venus opts for this route, could take place later this year. The company would go for Mach 2 or 3 on such a test.
I found that a bit of a misleading (or at least mis-matched) title/article... honestly a bit of a nothing-burger if they simply flew a drone without the novel engine design they are working on.
Which is why I prefaced the link with a clarification. I still considered it interesting because they're going beyond the seeming terminal phase of all these funky engine experiments, where they get tested on the bench and then we never hear about them again. These guys have made it clear that they want to fly the engine. In the spirit of "follow the money", they're serious.
Reactions: scaesare
