need info for model S wheel swap
Discussion in 'Model S: Interior & Exterior' started by bsholdice, Jun 19, 2017.
  1. bsholdice
    bsholdice New Member
    Bellevue
    considering swapping wheels & tires with a fellow model S owner.
    car1: 2013 85. 19" Model S Base Wheel.
    car2: 2015 p85d. 21" Turbine Wheel - Grey
    The tire sizes are identical - his p85d is not staggered. All 8 wheels are 245/35-21.
    My question is: what, if any, obstacles do we face? Can we just switch wheels or do we need to add/remove/change anythong. i.e. TPMS? Other than the price we settle on (and changes to efficiency, road noise & handling) are there any other concerns we need to be aware of and address?
    Thanks in advance!
  2. RichardD
    RichardD Member
    Texas
    VIN? Old style TPMS does not show the actual pressure so check that you both have the same.
    After you drive the car for a few miles it will learn the new tires if the TPMs is compatible you then tell it the tire size. 19vs21
    Your avatar in the screen will not update in my experience.
    hope that helps.
  3. kev1n
    kev1n Member
    Bay Area
    the only problem would be the TMPS, there are 2 flavors, one old, one new. the 2015 has the new one, you should find out if the 2013 has the old or new one. you may have to swap them.
  4. Garlan Garner
    Garlan Garner Well-Known Member
    Chicagoland
    All 8 wheels are 245-35-21? Even the ones on the 19" rim?
  5. Muzzman1
    Muzzman1 Member
    Los Angeles
    As above posts, the TPMS is the only concern.
    Regarding the screen avatar, you can schedule a trip to a service center, they will have to plug in a laptop to change the avatar. I've done it on 3 of my cars over the years. It requires you to be there in person with the car even if support says they can "probably do it over the air"
    ....and they are happy to do it for free in my experience.
  6. bsholdice
    Bellevue
    No that was a mistake on my part, of course the 19s are 245-45-19. I had meant to say all eight are 245 wide (his aren't staggered).
    I'll update my original post. Thanks!
  7. bsholdice
    Bellevue
    huh, cant edit posts on this forum?
