Need tech advice for adding camera
I am hoping to put a back up camera, same as original, mounted in upper section of radiator opening on the front.
The idea is to see how close the curb is when pulling forward into a space.
Dummy install, if it works: put a camera up front, wire to remote switch next to backup camera to choose which camera feeds the screen. Wiring is trivial, camera is easy to get, but what switch can I use? I would probably put the switch control under the screen and make it as small as possible.
