I know there are a ton of variables that will factor in here but looking for estimated cost you paid for a nema 14-50 to be installed. TIA
If it's next to your distribution panel the cost should be ~$500. Don't have your L pplTesla there when you get an estimate and tell them it's for a welder![]()
the duty cycle for a welder vs an EV is very different. I would not recommend this approach. ElectricIans aren’t going to charge you more because it’s a Tesla.
??? A 14-50 is a 14-50....
try googling the difference between a Hubble 14-50 and a Leviton one. Or doing a load calculation for a load center, the differences between continuous loads and non continuous loads and then share what you have learned with the class...
I 'learned' that a Hubble 14-50 should use #6 wire, be connected to a 50A breaker and is rated for 40A continuous load. I 'learned' that a Leviton 14-50 should use #6 wire, be connected to a 50A breaker and is rated for 40A continuous load. One does cost a bit more![]()
This is already covered. The welder is intermittent, so it can do the full 50A on and off. The EVSE is constant, so it can do 40A continuously. You still install the outlet the same way, whichever it is, as @nwdiver said.a welder isn’t a continuous load so you would do the load calculations different as well to determine if the panel can handle the additional load of the ev charger.
Ah yes, that part. They are close but a little bit different. I figured we were past that and that it was already a given that there was capacity and was just talking about the installation methods and wiring size, which would not be different. I think a lot of the disagrees with you were for the ridiculous statement that an electrician won't charge more for the quote because of seeing a Tesla. People frequently see 5X or more for quotes if the electrician sees that it is for a Tesla.the load calculation on the panel is different. I would assume you would know that.
Two is a lot? Lol. The other guy you are referring too just gave me 600 dislikes. Literally.I think a lot of the disagrees with you were for the ridiculous statement that an electrician won't charge more for the quote because of seeing a Tesla.
Bull. What they see is the company with the most aggressive advertising first, get a high price from the high priced company, then when they get other quotes from other companies that are lower they just assume it was because of the Tesla.People frequently see 5X or more for quotes if the electrician sees that it is for a Tesla.
No. I'm calling bull on your bull. This has been tested and proven multiple times. People have tested this and not in the way you are theorizing with apples to elephants with different electrical companies. They have had people call the exact same company to quote the exact same job but gotten 2X to 5X more expensive when the electrician finds out it is for a Tesla. Some companies won't do that, but a huge number of them do.Bull. What they see is the company with the most aggressive advertising first, get a high price from the high priced company, then when they get other quotes from other companies that are lower they just assume it was because of the Tesla.
I suppose I am predisposed to assume some about your comments since what we went through a couple months ago with you repeatedly and incorrectly recommending people use 6 gauge Romex for 60A circuits.well, perhaps before making an you know what of yourself you shouldn’t assume?
And this is what you said in another thread about pricing.the duty cycle for a welder vs an EV is very different. I would not recommend this approach. ElectricIans aren’t going to charge you more because it’s a Tesla.
Why should we do it for less? Why do you get paid so much to shuffle papers?
If people would pay me 10k to install their chargers I would charge them 10k. If they would pay me a million dollars I would charge them a million.
My time and knowledge is worth as much as I can charge for it.
Why Do Electricians Charge So Much To Install EV Outlets?
I have come across more issues with “professional” electricians work than I care for. At least if I’m doing it myself, I know it is being done correctly. Having it done correctly at less than 90% of the cost is just a bonus. Oh, some might worry with your appearance of a lack of common sense...teslamotorsclub.com
