Well it's not going to go under about $200 or so for any job just to have a company take your call, schedule you, do a bid and pull into your driveway. Then there are some parts and labor for putting in that box and doing the two wire runs to two different places in your garage. So yeah, maybe it could have been 4 or 5 hundred, but $800 isn't out of the realm of possibility. I'm just talking about if trying to add an additional 50A circuit means your main service needs to be upgraded, that can run a few thousand dollars.I am trying to do something like this, but the electrician quoted $800, which is more than I paid to install the original outlet that required pulling power from the panel to the garage.
Oh jeez--don't ever get one like that first one. It's plugging into a 30A outlet and then splitting it to offer a 30A outlet and a 50A (!) outlet. And then it's depending on your scout's honor remembering to promise not to ever overdraw the circuit. Don't do that. If you are going to use a smart splitter like that, only do one that splits to two of the same type that the original outlet is.Obviously would lose some charging capacity, but I thought (maybe not?) that it would be cheaper than buying a splitter like SPLITVOLT NEMA 14-30/14-50 SWITCH SPS - Splitvolt or Shop Home Level 2 EV Charging Adapters | NeoCharge
I just don't know that it solves your problem of the location and reach of cables though, does it? If you split it there, could you really plug in two charging cables directly and still reach both parking spaces? Wouldn't you have to buy extra extension cords, which are going to cost a couple of hundred more dollars anyway? So then that's more plugged connection points. It might be better off to spend the few hundred extra to do it right.
