We have a separate Neurio meter monitoring solar generation near the solar inverter and connecting to the Gateway 2 via WiFi. Installed this way because of the location of Powerwall (by our meter) compared to solar (by CU), and running cables directly from Gateway to solar neatly and in 15m or less would have been difficult. For the first few months this had worked without any problem, but then we received firmware upgrades and the communication began stopping randomly. This meant no solar data collected by Tesla and so no monitoring in the app, and using timed-based control is even less viable. Sometimes hitting the reset button in the gateway gets the two units communicating again, others we have had to get Tesla support do something a few days later (or maybe it just started again by magic).
Tesla support say that the Neurio connection looks "unstable" and we may have to consider some other solution. They have also blamed Wifi as unreliable, interfered with by atmospheric conditions etc. I find this weak/unreliable Wifi cause unlikely, why was it fine for months? Also since the Gateway is also connected to the internet via WiFi and the router it is communicating with is located next to the Neurio meter. If Gateway and router can "see" each other then so should Gateway and Neurio meter.
I have to think we either have an intermittent hardware fault in Gateway or Neurio meter, or this is a firmware problem. After all it is the firmware that changed, and it is firmware that has to check/re-connect and manage the communications.
Just wondering if anyone here has had similar experiences with additional Neurio meters and Gateway 2?
