My biggest concern is under normal conditions is the system large enough to charge the Powerwall during the day if fully discharged. And say during a power outage can they run my AC unit, which is a 5 ton package unit. And are the panels efficient in the summer heat
I live in the southeast valley outside of Phoenix, and I'll describe how I make it work for my system, and cut my SRP electric bill from around $3000/yr, to around 800/yr. Sorry this is so long, but I tried to state it in simple terms without complex calculations (which I actually did originally when sizing my system). I haven't made it a full year back around to peak summer with my system, but I did test my solar/PW setup during 4 days of about 107-109deg weather before it cooled down, and my calculations were holding solid. So here is my setup...
I have 4.0kW Solar, and 4 PWs. South Facing - but ultimately the direction doesn't matter when you have PWs, you just need to have a good estimate of your low winter production average, and high summer production averages. Surprisingly for me, my payoff was faster at this configuration (little solar, lots of PW - for my home size here in Arizona, and based on the most aggressive SRP rate plan)... than any other configuration with more solar and less PWs.
I give you this information, for comparison to your own homes usage. Ultimately, to make sense of what will work based on your specific Utility (APS, SRP, other?) rate plans in the valley, your home size, etc... you will need to know how much power your house "MUST" use during your utility peak periods for you to live acceptably comfortable. SRP lets me see my hourly usage for any given day in my online account.
My Size and High Level Power usage assessment:
- My house, at all times, uses as baseline of about 18-20kWrs (about 600-800 watts per hour for a 3600sqr foot house) no matter what, based on observing my SRP online hourly usage when I've turned everything off but absolute essentials. 2 refrigerators, small wine fridge, wifi, routers, 3 wifi APs, NAS server 24/7 a various home automation devices (hue hub, Smarthings hub, smart thermostats, etc), and clocks and such on various devices (oven, microwave, etc).
- plus about 15kWhrs of electric car charging each day on our chevy volt (Model Y soon to come!)
- We have 3 ac units, 4.5 ton, 3 ton, and 2 ton. The 4.5 and 3 tons AC units have to run a lot in the summer.
Power Usage of My Home during Peak periods:
In winter my house can sip as little at 20-24kWhrs for a whole day if we don't drive/charge out electric cars, and as little as 4kWhrs total during winter utility designated peaks-periods (higher rates), again during the winter, because we watch TV, cook, etc.
In the summer, the house can use as much as 150kWhrs per day when the heat is hitting 115 degrees and we make a couple 30-40 mile trips in our electric car and then charge them - also this peak is usually when low temps aren't going below 100 degrees overnight. The two bigger AC units are a must during the summer and I'm on SRP's solar plan, so peak window is between 2-8 in the summer, and I need the AC during those hours as both my wife and I usually are working from home. We do all car charging during off peak, so my main goal is to completely zero out all of my home peak usage, while still using reasonable AC during peaks.
AC is my key constraint for
eliminating Peak-period AC usage which is my primary goal for saving money, and minimizing my electric bill.
If I can eliminate my peak usage, ALL POWER usage is only charged at off-peak, and on SRP our solar plan off-peaks kWh rate charges are between 1/2 to as much as 1/3 the price of any other hourly rate plan (so like only 3.6cents off-peak per kWhr, vs about 7.5-45cents per kWh on all other plans). After measuring and checking my SRP usage, I need enough PW to eliminate my 18-24 (max) kWhr usage needs (with AC) during the summer peak periods.
So with that peak usage in mind, I also wanted about 25% slack, so that means my PWs needed to be at least 30kWhrs of storage. So that's 3 PWs, and I probably could have made this work for my home just fine. However, in addition to eliminating all peak power usage, I ALSO did want some "backup" capacity peace of mind. So in addition to powering my home, I added a fourth Powerwall to both give me some Backup capacity, but also that gives me even more slack if during the worst summer months we also have our annual monsoons that make it cloud for several days in a row. So, 4 Powerwalls, but only 4k of solar.
Financials:
So just by zeroing out my peak usage with the PWs (every single day), I've cut my electric bill at minimum of 50%, so in half - EVEN if I used the
same amount of power as before I was on the solar generation rate plan, but just by shifting it off peak via the Powerwalls and having super cheap off-peak rates now on the solar plan. In reality, in addition to those savings, I'm
ALSO using about 18-22kWhrs less per day with my small 4kWhrs PV system.
So, bottom line, for me to maximize savings and payback, I need just enough Powerwall (
maybe plus a little slack for cloudy days, lets say 20% slack over my calculated needs for the worst peak period usage) capacity to cover my max summer peak-period usage. Then, I need just enough solar to to cover replenish the PWs each day. In my case, in the worst of the summer heat I actually have slightly less Solar than I need, but because I built in "slack" in the PW capacity (by getting 4 Powerwalls) I can finish "re-charging" the Powerwalls on the weekend. The reality is this is only going to be needed during the worse 8 weeks of the summer. Right now in the winter, I only need about 25-35% of the capacity of the 4-PWs but that allows be to extend the life by only running the Powerwalls in the 30-60% charge range, until I need the full range as summer heat ramps up.
If you calculate using less than the
Bottom line savings:
- Winter Low billing months before I had solar/PW=~$90-120; After Solar/Powerwall monthly billing=$45-60
- Summer High billing months before I had solar/PW=~$400-475; With Solar/Powerwall monthly billing=$125-175
Hope some of this is useful for comparing to your situation.
