Nicely compiled video from SpaceX of the Falcon Heavy and Starman launch, including by the way the Center core missing the drone ship!
The timing of the legs are preprogrammed. Since the outer engines didn't light and the booster hit at 300 mph, then the legs didn't have time to actually deploy. It's also why SpaceX has the booster come in where it does then shift to the ASDS at the last second. This was a perfect example of the smart planning designed to protect the ASDS.Its interesting if you take a look at when the booster is attempting to land on the drone ship, the landing legs aren't even deployed. So if it was right on target anyways, would have done much more extensive damage to the ship I suppose.
Very inspiring. We drove down from Ohio to watch it. Our first launch ever, we will go to every falcon heavy launch till I die. Got this a week later.BTW- Awe inspiring video huh?
not to pick nuts, & not certain, but didn't they post that the reason the main section couldn't land on the Sea barge was because 3 of the centre rockets' 9 engines didn't fire?My favorite shot in that video is at 22 seconds in; close up of all 3 cores with 27 engines lit!
It is as @Grendal explained above. The launch was nominal. Center core re-entry — after 2nd stage separation — was not nominal. But it’s an easy fix for next time.not to pick nuts, & not certain, but didn't they post that the reason the main section couldn't land on the Sea barge was because 3 of the centre rockets' 9 engines didn't fire?
They just ran out of "lighter fluid" known as TEA/TAB
So I'm just curious is the TEA/TAB for all nine engines stored in one vessel, or are there individual tanks for each merlin engine? If there are individual TEA/TAB tanks within each engine, would it be possible to detect a failure to light in one engine, and then immediately failover to one of the other 6 idle engines?
