Newer Ohlins TES MX00S1 on my 21 MYP, review lite.
After an abundance of research, and sometimes being practically overwhelmed by the litany of opinions here and everywhere else on the internet,
I have settled on to what I believe to be a huge improvement in the suspension on my 21 MYP.
FYI, I am running a square 275/40 zr20 setup on considerably lighter wheels. So some more meats for slightly added cushioning.
I have only had these Ohlins on for about a week at this point but my initial reaction when I first stepped into the car was that this is a totally different car on local roads and the highway. I also live in SE PA...our roads are pretty much garbage right now after the winter.
That harshness of small and larger bumps has all but disappeared.
The intense head tossing feeling is very well gone over certain roads.
The side to side swaying when moving in and out of parking lots gets soaked up.
The chatter on some roads and subsequent resonance from the hatch gets dissipated quite a bit.
It doesn't lunge much at all when accelerating or decelerating, even set to its softest setting.
On the highway it gives off a bit of that floaty feel without bounciness.
It does all of this while still maintaining control and feeling precise.
It seems that the cabin is a bit quieter and road noise is lessened slightly as well.
I think these coilovers are going to ruin me though, we took a trip in my wife's CX-5 after a few days, and what was a pretty bad ride before feels insanely worse now.
Overall, these clean up the older performance suspension very well...the car doesn't feel so hectic and squirrely...much more comfortable if that's what you are looking for.
I haven't dipped into the tighter end of adjustments yet, but seeing as im looking for comfort, it is probably where I am going to stay 80-90% of the time.
I have to plug ZEVcentric and Rishie for helping out with these. Solid dude. :cool:
For the purpose of transparency, he didn't ask me to write anything up here, and I left an almost identical review on his website.
Very nice!
I was just reading about this kit today.
What height did you set it at, got any pics? Looks like these only go 10mm lower than stock (vs 30mm on the MU00S1 kit)
The 10mm lower is just what you will reach from the settings in the mounting instructions, it’s not what it max can go, ohlins never does like that.
The adjustment range is about OEM height to -35mm lower. It’s definitely possible to go lower if you are a little creative removing lock rings etc.
Very nice!
Yes, you can only go 10mm lower(on the performance version)...im probably just south of stock around 5mm lower...I didn't go the full 10mm, don't know why?
I figure things will settle in over time.
I don't have any pics currently but maybe I'll get some up once I get a chance to clean it up.
I think it is noticeable but like, Im always looking at my car going, is it lower?, it looks lower? maybe a little?
It looks nice. Drives nicer!
So you mean that you bottomed out all the preload adjustment front and rear and only got 5mm lower? Because it’s supposed to go way lower than that so it’s something wrong if not.
I don't know...I didn't install them or have the ability in my one car garage. Recommended is 10mm lower than stock max for the MYP, can you go lower...maybe...will you start to get coil binding? I dunno.
Okay good, just dont wanted false info to be spread.
The 10mm lower is what you get from the recommended measurements in the instructions. It’s not what is the maximum adjustment range, I know for a fact that the TES MX00S1 will lower the car -35mm, and even more if you get creative.
You won’t get coil bind by reducing preload.
Glad that you are happy with your new suspension!
Reactions: Sloshy2
I have swift springs. My kit started life as a R/T and used a 178mm rear spring. But it ran out of preload and I swapped to a 203mm spring. The front needs a 254mm at 7k and longer if you go to 6k. I had to stick with the adapters that came with the kit. If you get it from Redwood, they can get you the rate you need in the length you need to work with there setup.
The longer spring limits how much you can lower the car. -5 to +20 is about the range
Stock front shock has 155mm of stroke and the rear has 160mm.
Front ratio is .66
Rear shock is .87 and spring is .60
Front ratio is .66
I see, thanks for the info. If you were running out of spring preload you must have extended the rear damper usable stroke beyond the default or removed some of the packers.
I was leaning towards the street tuned kit, but since that doesn't use an upper adapter I'm not sure it would be as easy to change the rear spring with a readily available Swift spring or if requires a spring with custom geometry.
I would 100% recommend the street kit unless you are building a track car or want to run more than 10mm less than stock height.
Stock springs where sized wrong and had absently zero preload capacity. This gave you only shock length to adjust ride height. It was a very compromised setup with no real adjustability.
