At the point where kick stage sep was supposed to occur there was no announcement, and nothing at the end of the webcast to indicate there were any issues. So...?
Here’s a screen cap a second before they shut off the speed/altitude display. The altitude had fallen from a peak of of about 194km to 166, while the webcast host is talking as if nothing bad had happened.Actually the timing was right around the time of the battery hot swap. It definitely didn't get to orbit which is where the kick stage would separate. The video they were showing us shut off at 190 km in altitude and 13,680 km per hour in speed. Right around that time the telemetry (which still seemed to be working) showed the speed dropped off to a trickle and altitude continuing to gain from the upward momentum. Maybe a turbopump failure that wasn't from the batteries.
Why does the acceleration have so many jitters and not a smooth line? If you are burning propellant at a constant rate, then your acceleration should steadily and smoothly increase as the overall mass is reduced, which I would think should be a smooth line too.
And "jitters" are in the velocity data (due digit cut and frame rate) it just doesn't show in velocity, due... you know physics... Further reading:How does the speed curve not reflect the acceleration jitters?
Well it certainly was visually noticeable. I have no idea if that much roll was nominal or not.It may just be me, but it seems like a pretty dicey roll-shudder when the side boosters separated...?
