An update on my engagement with the NSW Net-Zero team.
The requirements for fast charging operators has been released - website
here and PDF of the application and funding guidelines
here. The minimum performance standards required for an eligible application start on page 21 and the requirements include:
- a minimum of 2 chargers to service a minimum of 4 bays concurrently (i.e. 4 charging plugs)
- a minimum of 2 charging bays rated at a minimum of 175 kW per bay
- a minimum of 2 charging bays rated at a minimum of 350 kW per bay
- includes redundancy in the system (e.g. an additional 22 kW AC plug)
J1772 appears to be dead as far as this document is concerned. It’s Type 2 for AC charging, and CCS2 and CHAdeMO for DC charging.
This document also has lots of maps showing the “priority zones” for charging locations (pages 61-70). I’ve alerted them to what appears to be incorrect traffic data in the Master Plan interactive map and they will investigate it.
The FAQ also mentions
“Successful applicants for co-funding will also provide technical support for EV owners and provide a number to call and report faults” but no support SLAs appear to have been defined.
I forwarded them the link to the Guardian article on the EV charging experience from a ‘non-expert’ point of view.
Some additional requests I have put to them gleaned from here and elsewhere:
- Parking laws should be amended so that if an EV needs to park at a legacy installation contrary to a sign (e.g. front to kerb instead of rear to kerb, or contra to the traffic direction in parallel parking) in order to charge due to the location of their charge port or the length of the charge cable, that should not be an offence.
- Consider funding to Local Councils for trials of pop/pull-up kerbside chargers or use of smart poles that suits that particular area.
- Consider low cost loans or grant assistance to existing Owners Corporations to fund electricity backbone upgrades and/or installation of EV-ready systems to enable any unit owner to then add EV charging at their expense.
- There needs to be more focus on dealing with EV charging issues at existing strata plans, and not just updating the building and development codes for new strata plans (including removing the power for an OC to block an individual unit owner installing EV charging in their allocated parking space at their own cost).
They said they will forward the comments about existing strata plans to the team responsible for making buildings EV ready - so that’s a hopeful sign.
