Just installed an Oem refreshed bumper retrofitted by Arvin
I notice the new bumper fitment have less gaps between headlights and fenders.
Dent on hood needs fixing
here's are a couple of pictures
Wait, I'm confused. I did the upgrade as well myself. I don't understand how the trim on yours works. I used the stock 2015 left and right under hood panels but the upgraded front part of the under hood panel. In order for them to work together I had to cut the front panel and tape it to the side panels. How did you do yours?
Yes please see attached, all original trim. Only gap is between the new grill and latch trim. I believe someone on the forum makes a filler piece with a 3D printer, but I don’t mind the gap.
The old trim still fits all you have to do is remove 2 of the 4 push pins so only the middle two line up behind the hinge since the new grill doesn’t have the outside two holes. The two push pins hold it plenty, I’ve done the same to the dual hinge car and single.
ya custom honey bee front grill I cut to fit around the auto pilot sensor.
Can you show me what you mean? I need to fix mine to look cleaner.
dsancho
did your temperature reading on your dash fluctuate ?
