dhrivnak
With winter coming can one turn on the seat heaters? It would be nice to slip into a warm seat on a cold day? I could not find a reference in the Roadster manual. Thank you
Unfortunately, no. They are controlled with a switch, not a setting that can be accessed (but I agree, that - or preheating the car would be great).With winter coming can one turn on the seat heaters? It would be nice to slip into a warm seat on a cold day? I could not find a reference in the Roadster manual. Thank you
I tried this. Unfortunately on the app the picture of the slider and the connecting plug vanish as soon as I try.if you move the slider to the right to re-initiate the charging , that would result to the same as top-off.
don't do this to often in range mode , not good for the battery
Hmm, I lost Push notification on 22. October and haven't received any since that.
I thought it might have been caused when I went from the Android app to the iPhone 5s.Same here.
The feature 14 has been set on 8 to stop SMS messages, but app notifications kept on coming. About 1 month ago reception of notifications in the app suddenly stopped. To be sure I set feature 14 on 0 but also SMS messages do not come back.
When the notifications still worked I sometimes received 20 times the same but did not pay attention since it is better to get it 20 times than no messages at all
I really miss the notifications if charging is interrupted.
How can I reset this function or is the software getting unstable?
Same here.
ditto ... I too lost Push notification recently, I thought it was Android 6.0.1 ??
and I've been re-installing android app and trying all sorts, but no app notifications.
Markwj, thank you so much for getting back. Yes I see Open Vehicles | Open Vehicle Monitoring System is back up but the new iPhone app is still not working for me. Just the grey blinking antenna. I can log into the server so I assume I properly know my userid and password. However, I assume I am doing something wrong as I am new to iPhones and Apple in general and do not see issues being posted.
So any advice would be appreciated.
I sometimes have swapped Module with Server password... So, I suggest checking that...
I have both Android and iOS apps working @ the same time.
Good suggestion but not sure that is my problem as I have tried 3 times even removing and reinstalling the app. I may have gotten wrong the first time but I hope to goodness not the last two.
I did hard code the ip address in the app after reading it was changed.
I have OVMS Server set for tmc.openvehicles.com and port 6867... Hope that helps
Thank you I swapped back and still no connectivity so if still and issue tomorrow, I will send a note to the openvehicles help email. It does look like the problem is limited to me, likely a password. ARGHHHHHHH and thanks
