cheekedave
Who the hell is getting out of their car? I plan on living in mine once I get it. I don't need a door handle, thanks.
You may be right but that only shows the stuff that's open not the ones that are closed.From the screenshots we've seen of the screen when it is in park the only things you can open from it are the trunk, frunk, and charging port.
I saw a second video recently that showed the door handle retrieve very elegantly back to its resting position it shows great quality.You don't need two hands to open the outside handle. You push the larger end with the thumb and the skinny end with push out and your grab that with the rest of your hand. Jaguar and Aston Martin have similar handles.
No. In the pictures that show those controls on the screen you can see that the hood/frunk is closed. Which implies that the "Open" means to press that to open the indicated cover.You may be right but that only shows the stuff that's open not the ones that are closed.
I have that in my Cadillac ELR, you push a button to unlatch the door and push
Most likely secondary method in case of emergency or accident and electrical power is cut which wouldn't allow the switch to work. I assume this method is not intended to be used on daily basis.I get that. The push button latch is not the news (at least to me). The news is that there are TWO methods of opening the front doors. I'm curious about the second method...
This shows the two separate mechanisms that may be used to unlatch the door (electric button at top, mechanical pull latch below):
Model 3 interior
On the other hand, our MB currently has 24 buttons in 17 physical nubs, pads, and knobs just on the driver's door. Not counting the actual door handle and lock stick.Elon doesn't want you to have inside door buttons. You don't need them. That's what the touch screen is there for. It can do everything.
