WannabeOwner
the button on the charge "nozzle" that opens the charge port as you approach the car which saves you 5 seconds as opposed to pressing the charge flap
MUCH bigger advantage is stopping the charge without having to dig phone / key out of handbag / pocket or reach into car to stop the charge, and then get back out to unplug. Obviously not a problem for folk that always have phone-in-hand ...
Tesla wall charger supports 3-Phase, if you happen to have that, and also load-sharing for when you have 2+ EVs on your drive. There are OLEV ones that do that too.
If the charger is going to be somewhere prominent then one of the OLEV ones may be aesthetically more pleasing to you.
OLEV chargers tend to be a bit more expensive ... so installing a non-OLEV charge (because you like it for some reason) may only cost £200-ish more.
Whatever you install Sparky will have to run the same length of cable to get to it etc. many/most? OLEV installers seem to be looking for easy jobs, get-cash-and-leave ... so if yours is complicated you may be better off using Local Sparky - who will let you route the cables yourself, and leave everything open for Sparky to inspect, or do it far cheaper than OLEV fitter would. OLEV approved fitters unlikely to be interested to do any sort of self-install deal ... but if in, e.g. Garage, then your Sparky may be able to provide the supply / distribution board (assuming it is complex and thus worth getting cheaper Sparky to do that bit) and then OLEV just come and "hook it up".
Simple wiring (charger location within a few feet of the supply / distribution board, and you have a 100AMP fuse, or failing that not much smaller, then £200+ for install (and then £200+ to top up the OLEV grant for the Wall Charger of your choice)
If your Location said something more specific than "UK" then folk here would be able to make recommendations if they know someone in your area.
