Has anyone gotten above 573KW (the previous maximum at 1762 amps) with 36.1? Any TM-Spy logs showing what the new maximum current is?
I'm also curious about how it affects the P cars. Is 5% or 50hp enough to change the stated 2.4 sec 0-60 times?
Yes, please. Very eager to see these results.
Good numbers! I think the update doesn’t necessarily up the HP to much, it is more likely the curve of delivery and drop off (torque and HP).Did some pulls this morning at about 87% SoC. Without launch mode, max power was 557kW. 155.5 and 367.5 front/rear. In launch mode (on normal asphalt, not a prepped drag strip so not sure if it was traction limited) peak was 575.7, 181/375 front/rear. And I'm not sure why the front + rear peaks only add up to 556
I just got 2019.36.2.1, installing now but I assume it's just bug fixes.
Agreed. I think it's more like 50 more HP from the front motor during certain points in the curve when the rear is otherwise traction limited anyway. The release notes implied as much.
That's interesting because the rear motor is the same as pre-Raven vehicles. It's only the front motor that shares the fixed magnet design of the model 3.In this TRC video from July with his raven Model S, the max front and rear hp occur simultaneously at 177.5kw and 360kw. Max battery power was 578.9kw. The sum of new numbers is 18.5kw higher, or about 3.5%. It looks like most of the gain is from the rear motor, though. The TRC car was at a 99% soc vs 87% for the new numbers. There could be more power available.
The release notes also say that it was the front motor that was tweaked for more power.That's interesting because the rear motor is the same as pre-Raven vehicles. It's only the front motor that shares the fixed magnet design of the model 3.
Then perhaps it was just a good run and/or SOC difference?The release notes also say that it was the front motor that was tweaked for more power.
Elon also said there would be an increase of 50 hp, but these new numbers are only 25 hp more. Could be that the font motor lost traction and was limited.Then perhaps it was just a good run and/or SOC difference?
This is my max on 32.12.7
2017 P100DL
I used to get 565-575kW
Yes, of course
