Hi,
Any advice on how to get the rear caliper piston fully retracted? I'm installing a Racing Brake 2-piece rotor, which is 1mm thicker than stock performance rotor. I was able to disable the e-brake by following the instruction from another thread, the stock rotor can be removed with ease, but it doesn't quite have the extra 1mm needed for the thicker rotor.
I recall seeing a similar piston with two pins on the rear brake of my other cars. Those require a rotation tool to screw in the piston. I hope this is not the case with P3, as there is no straight on access to this piston. Attached is the photo of the caliper/piston.
The instruction I have follow is far:
Thanks in advance for your input.
- Put the car in tow mode
- Disconnect the electric plug to the brake caliper on the side I'm working
- Take stuff apart, swap rotors, reverse
