I hope by "track damage" you are not including a few runs down the dragstrip on occasion. In my opinion there is no difference between showing off to your friends by demonstrating ludicrous and driving down the strip. On a yearly basis I certainly have stomped on the pedal more on the street than than on the strip. As you know I rarely use launch mode as there is no advantage to it and the reaction time will be slower.
Tesla would have to lay out the ground rules.
Caution: speculation and SWAGS follow:
Without question, I think the point to be taken in all of this, is that they appear to be trying to limit either their current, or anticipated warranty exposure, from claims arising from the use of launch mode.
Otherwise why take the step that they did?
I can think of no other reason for only targeting those cars with launch mode.
They may know something unflattering about launch mode that we don't know yet.
Why target "launch mode" and not just plain garden variety accelerator pedal stomps?
If it is the case that launch mode and "long term" use of it can lead to problems, and from what they've written it appears that it can, well then the simple solution would have just been to eliminate launch mode from any cars in the fleet.
But eliminating launch mode would be an admission that it was half baked when they released it and adds nothing from a performance standpoint.
Eliminating it would trigger questions as to if performance suffers as a result of its absence.
How would Tesla answer that question?
Eliminating it would be just as big of an embarrassment as this is. If not bigger because they've gone to the trouble to tout 0-60 times so hard......presumably using launch mode.
So now it's no longer "expendable".
To then turn around and say, "we're eliminating launch mode from our cars, but our 0-60 times are the same with or without it and don't change as a result of our eliminating it", would be an admission that it really doesn't add any benefit performance wise, which many in here already believe.
I suspect that what they've found....... is that the only thing that launch mode is good for, or is going to end up being good for.....is breaking parts. Causing more damage than it's good for.....possibly or even likely within the warranty period.
That's why they don't want you using it.
If that's what they're fearful of, then perhaps the best move, if the goal was to limit launch mode's actual use, and thus limit their warranty exposure as a result of it's use, would have been to focus on the venue where it was most likely to be used.
The drag strip.
If this is the case, then I can deal with that.
But not permanently cutting my power.
