Parking Sensor Issue After Car Wrap!
joshwa_RN
45
Roseville,Ca
Recently got my Model Y wrapped and noticed that when I parked my car back in the Garage the front parking sensors that tells you how far something is, are not working anybody else have this issue? (Attached is the photo of to color change I Did)
NJEV-Don
225
149
Northern New Jersey
The color is...unique to say the least. If you’re happy that’s all that matters. As far as the parking sensors etc. just go back to the detailer shop and explain to him. They can cut around the sensors so you won’t have any issues. My detailer did that for me when I was getting PPF installed. It should not be an issue. It’s a very simple fix.
joshwa_RN
45
Roseville,Ca
I also email i1Tesla from You tube apparently its the new update
Spacep0d
996
1,153
Wildomar, CA
So what you're trying to say is that this is the color you'd see inside the diaper of a newborn? I actually love how unique this is. Would I choose it? No. Do I respect the effort? Absolutely. :D
OP, good luck with the sensor issue!
Reactions: NJEV-Don
Gigaron
313
140
San Francisco
Is the update definitely the issue? Just had my car wrapped and having the same problem.
Plenty of threads on this topic already. My problem started after the PPF cured. As soon as it was cut away from the sensors the problem went away. You need to cut on the outside of the white rings surrounding the sensors.
Reactions: JasontheBeaver
Murattukaalai
443
90
Denver
Problem is the vinyl that was installed. On a warm day it works and also works I use heat gun on the sensor wrap and push it in a bit. Once cold it stops working again.
thxphil
30
33
Seattle
I have XPEL Stealth (Matte) on my Pearl White MY and front sensors no longer work. I don't want to cut them out so I just deal with it.
