I cannot seem to learn just where the nose of the MS is by sighting over the frunk; try as I might, I always stop short of the intended spot or a bit too close. Low obstructions are not detected by the front sensor.
However, I found a solution. Do this:
- Sitting in your normal driving posture, sight down to the ground at the acute angle formed by the left mirror bracket and the window sill.
- This will identify a spot on the ground. Remember the spot (or perhaps with the help of an assistant, wife mark the spot).
- Exit the car and estimate the distance of the spot with respect to the nose. It may be a few inches back of or in front of the nose.
- Remember this distance and use it to estimate the position of the nose next time you park.
