Yup, that's the one I just found and mentioned in one of my replies last night! Seems to be quite a unique engine/model, I see no name-brand or off-brand clones. Specs are better in all respects, except being an acceptable 10 lbs heavier than the WEN. Quality and longevity unknown, but reviews say it's very quiet when it is working. And while it's not the 18" wide I was looking for, neither was the WEN - it's actually narrower at 21.5" than the WEN (23" with wheels). I've accepted I'll need to take out or move a small bush to store either of them.
I actually placed an order this morning. Just hoping for a relatively undamaged one, apparently their factory packaging can't handle the delivery abuse by UPS. If it arrives OK, I'll test it out and haul the WEN unused back to Home Depot. If it's destroyed or DOA, I'll fire up the WEN to make sure it's OK, and have Costco come back to pick up this one.
Yay, success! The A-iPower from Costco managed to arrive with no broken panels - it's got a lot of plastic housing like typically smaller inverter generators, and I could see from the choice of thin foam cushioning inside the box, how sharp impact to a side of the box could flex/crack a panel without even any damage to the outer cardboard. But perhaps since the company seems to be located in SoCal, it was drop-shipped only a six-hour truck ride away, so less opportunity for UPS to manhandle it.
Spent a good part of the day making sure it's working fine. Tested the pull-start, electric-start, remote-start all fired up immediately. Verified the floating neutral, though based on this thread no longer concerned about neutral-bonding for my use case. No means to hook up any 240V loads or test the BPTM, so did the break-in at 120V running varying loads on propane - fridge, aquarium, gaming PC, and hairdryer. Inverter + full housing + low idle mode makes for a pretty quiet unit - at 25% load, I'd say almost as quiet as my tiny 700W generator, basically can only hear it from nearest bedroom inside the house. Pure sine wave seemed good, a small UPS I plugged in didn't complain at all.
Best part, while the WEN was wider than listed (23" wheels vs 17.5" spec), the A-iPower was significantly narrower (19" actual vs 21.5 spec). Both units actually same 17.5" body width, but the A-iPower had mostly recessed wheels like a rolling suitcase. Bottom line - no shrubs have to be sacrificed for this whole endeavour
, as it can roll in and out of my preferred storage area,
The WEN will go back to Home Depot brand-new, though would have been a decent alternative. By coincidence, their product support just e-mailed back yesterday with official instructions for unbonding the neutral. Sure enough, that alternator end cover is supposed to just slide off, and the one jumper wire was right there to be capped off - nice to know they officially support converting to floating neutral
Feel pretty confident that the furnace blower and any other appliances looking for proper ground should work fine with the BPTM, as they will see the same main panel ground as they currently do, and all GFCI/AFCI wiring is unmodified too. Will do a bit more break-in on the unit and then change the oil before putting it away, but almost giddy with anticipation for the next big storm....
Yeah, yeah, I know this whole thread has been a bit old-school archaic compared to a Powerwall, but it's still my shiny new toy.... thank you all for indulging me
