See, THIS is the PowerWall product that Tesla should be installing in homes -- something that can comfortably power the whole house for several days, not a couple of rooms for a few hours. Let's hope your pictures get Elon's attention.
looks fantastic, wish I could do any solar on my condo.
here is some food for thought for you; you likely won't own this house/condo forever, so while it's fresh in your mind, make up some documentation, and perhaps contact a local electrical contractor, and get them familiar with your installation. The idea is, if someday you want to move, you'll have a local electrician that can be contacted.. Imagine a buyer walks into that electrical room for the first time, its a bit overwhelming. Not saying you are going to sell/move anytime soon, but it's something you have to think about. on the plus side, you're probably one of the few "netzero" houses in the neighborhood, and having small or no power bill is a huge selling point.
LOL - you are becoming as famous as EM.
They do, wk's 192KW is the equiviliant of (2) Tesla commercial Powerpacks (100KW each). They just won't fit INSIDE most homes.
Yeah, a setup like wk's is very adventurous indeed and even if you had off the shelf products, not many people would implement it. I believe a 100kW unit would weight about 2000 pounds? Try lifting that up and down the stairs
That's actually a minor bullet point on my todo list. Not visible in the photos (because I moved it) is one of those portable A/C units that vents out a window on the other side of the wall where the transfer switches are. It's doing the job for the moment, but I will be installing a more permanent solution to conditioning this space soon. A combination of a heat pump hot water heater ducted to this room, a mini split A/C unit, and an exhaust blower all on thermostats.
Believe it or not, under normal loads and PV regulation it doesn't get deathly hot in there. On Sunday I charged my Model S at 20kW while the A/C was running in the house and such (so about 25-27kW load), and I had the portable A/C unit off at the time. It got up to about 85F in there and held around there, most likely in a battle with the ground floor central air unit at that point. But it's good to know that it doesn't get to ridiculous temperatures even without special conditioning.
Awesome, you were only using 3.5 of those radians at that time. You did a really great job. Very professional looking.
You probably shared this earlier but this thread is so long I don't remember the reason. Why did you go with the MidNite Classics over the FlexMax80's?
Could you do some type of exhaust fan to vent the heat to the outside to save energy? Possibly even thermosyphioning? This might not be an option if you can't create an envelope around your utility room to create a seperate "conditioned space".. Dealing with BOS heat indoors is a pain.
Thanks!
Actually, the Radians kick on in 4kW increments for efficiency purposes. So six of seven of the eight would be running at a 27kW load with about a 3.9kW-4.5kW load on each. I'm working on a script that works with the MATE3 USB connection that rotates out which inverters get utilized under load to balance the wear a bit, also. I'll have to physically change the master one occasionally to do the same since it's required to be on port 1 of the HUB10.
ike if you plug your car in, how well do the inverters prevent and react to the sudden load.
Plugging the car in is not a good example because the car ramps up its current draw slowly. Things like AC Compressors turning on are more likely to cause a sag.
Oh, I miss understood how they came in then. I thought inverter one would bring up 4kw, then the other 4kw in that unit then inverter 2 would bring on the first 4kw. Allowing the rest to fully sleep. So with two inverters and a 7kw load each inverter would be providing 4kw
We have a big Outback Power training session tomorrow. I'll talk to one of the engineers about rotation of inverters to balance their usage. This would even be good in a single unit to go back and forth between the two units.
Another question. Are you noticing any voltage sag when big loads come on? Like if you plug your car in, how well do the inverters prevent and react to the sudden load. This would be in mini grid mode.
I have seen magnum 4448pae inverters sag enough when a well pump kicks in to cause tv's to turn off.
I wonder if the startup capacitor on it is wearing out or failed?My one large A/C unit is another story, though.
Something like this may help:
Compressor Saver Hard Start Capacitor Model CSR U2 - Hvac Controls - Amazon.com
"As for voltage sag, under 55kW load (highest I've been able to put on the inverters) I see about 1.3V sag on the DC side (MATE3 is only good in 0.4V increments and shows a 1.6V sag). Not bad considering that's about a 1400A load."
I think that's the best you could have done in the circumstances, but it's still burning up 2kW! I totally understand that low voltage was the only option open to you with currently available equipment, but it does show the wisdom of Tesla/SolarEdge moving to high voltage for Powerwall.
Regarding the AC, have you thought about trying to run 3 of the Outbacks as 3 phase and investing in a 3 phase compressor? You would get much higher efficiency and lower startup current.
I sort of assumed the reason you had 8 inverters in the first place was to provide startup overhead for the AC. Do you actually have 55kW of load?
It was sort of my point that you had to go low voltage because that's what the currently available off-grid inverters support. But SolarEdge and Fronius already make on-gird inverters that support high voltage and clearly they will make these off-grid capable in order to support Powerwall. In SolarEdge's case, they have stated their solution is compatible with their existing inverters; it's not completely clear what this means, but I suspect it means all they need is a software update to the inverter and a replacement unit for the AC/DC disconnect that adds a relay controlled by the inverter to isolate the grid.
I would be interested in seeing end-to-end efficiency numbers for your storage solution.
Your system will always win for awesomeness and being first!:smile:
My one large A/C unit is another story, though. I actually changed the power save settings to keep two inverters (4 modules) out of power save to compensate. When that unit kicks on lights flicker as the other Radians come out of power save to handle the surge, sometimes six of them even though it's only a 3kW compressor (which probably needs replacing given this surge power). Works a little better with master power save set to 3 (4 modules/16kW capacity on all the time) at the expense of higher idle load. I may bump it up to 4 or 5 if it doesn't solve the surge issue. Only things in the house that react to it are some LED lights and a couple of UPS's. Aside from that it seems OK, but would be nice if they handled that particular surge a little cleaner, though.
