Tesla 940
I'll complete the questionnaire in the next day or two. Regarding the CAC (what ever that is), unless the instructions are on the level of "CAC for Dummies" I'll be hopeless.
A Tesla service tech can read the CAC value for you. If that's not practical, there are a couple of other methods for getting it. If you've already submitted a survey report, send me a private message. If you haven't submitted a report yet, go ahead and submit without the CAC value and put a note in the comments that you need info on getting the CAC and I'll contact you.Some people probably don't know how to get CAC, so perhaps you should post the instructions again.
I don't know if the techs can pull the CAC out of the logs. So far, we've identified numbers in the log file that are close to the CAC value (average and minimum brick Ah), but aren't quite the same. I've seen cars where the CAC value is near the average brick Ah number in the logs, and others where it's closer to the minimum, with significant differences between the two.Can the Tech service do that from a log file sent, or do they need the car in the shop for a full bleed test.
With the vehicle off, touch the VDS screen to wake it up. Then touch the "i" button and then "Vehicle Info".TOMSAX,
I'm getting the information for the survey but I can't find the screen that gives the Assembled Date. I have a 2.0 or 2.25. Any more information would be helpful. I did buy the car new so an Assembled Date is pretty easy to estimate.
Thanks,
Don
That's my favorite guess at the meaning. Have you heard from a reliable Tesla source that that's the official term?"Calculated Amp-hour Capacity"
Excellent! I'm glad to have a good answer on that. Thanks!Yes, more than once.
Through a bunch of careful logging, I found that CAC corresponds perfectly with the value that Scott uses to calculate brick min amp-hours, but I had to use a slightly different scale factor than what Scott uses.So I'm curious how this is different from the amp-hour numbers we get from the -b option? The parser reports my CAC as 151.97 and my brickahmin as 151.64.
