Post your Tone audio settings
Post yours
Any better settings?
I always learned that the smiley face setting is the best
It’s whatever floats your boat.
Do you like photos over saturated?
Or more natural looking?
Your music might already be V shaped.
The Audio system in the car may already be V shaped.
Adding more will likely make things worse.
Without measurements, just randomly throwing the same correction at every system is kind of silly.
What if the midrange is already weak?
Your Personal Guide To Different Sound Signatures:- Understand Your Audio Gear Better!!
I set most decent audio systems flat.
Post yours
That's a lot of bass. What volume are you normally at with those settings, and what kind of music? At anything above say volume level 4 in my car, the bass from the reggae music I typically listen to on my commute would likely drown out the actual lyrics.
