at the risk of jinxing myself, i have taken my probably 20% or 30% success rate with the phone key on my oneplus 5 to 100% over the past few days.
that's not a typo...it has worked every single time, both entry and walk away lock. it also has worked every time when walking up to the trunk (which almost never worked previously), and also when going from trunk to driver's door (which almost never worked on the rare occasion i got the trunk to work). it has taken the phone key from nearly unusable to almost perfect (i don't want to declare it 100% perfect yet because it has only been a few days...too small a sample size, in my mind).
download and install this app:
https://play.google.com/store/apps/details?id=com.bridou_n.beaconscanner
go into your battery management settings, and make sure the beacon scanner app is set to not optimize battery use. then, open it and run a scan (press the play button). leave the scan running and exit the app. that's it. it will keep scanning in the background...if you go back into the battery settings after a while, it'll show as active in background for however long you've had the phone running.
disclaimer: this will drain your battery a bit...my idle battery usage went from about 3% to a little under 4% per hour (according to ex kernel manager), but it does seem to work. at the very least, it has helped a ton in my case. to me, it's worth it if it means i can have the phone key work most of the time.
YMMV of course, but hopefully this will help someone.
tech details: oneplus 5, running android 8.1.0 (aosp extended rom), august 5, 2018 security patch level. tesla app is version 3.6.2-354, car version is 2018.42.2.1 e1784f9.
