When the Powerwalls are in Backup mode, they will balance the micro-grid by charging the batteries inside the Powerwall as necessary. If you are going to use an inverter larger than your typical house load, you should probably run it through the Powerwall system solar CTs so that it properly registers it as generation. That was my original plan, but it's not necessary with a small inverter. This scheme is intended to prevent the Powerwalls from running out of energy, so the high SOC frequency shifting should never come into the picture.Just curious if you've tested the scenario where the small runtime extended inverter (even if really small) provides more watts than the house load? Does the small inverter just ramp down in that scenario because it's aware of the house load?
The inverter I chose to use is just blindly pushing battery energy into the AC outlet it's connected to. If you connected a solar panel, it would modulate more as the voltage varied.
In the specific test that I presented in the first post, I am only feeding power in at 120VAC. That means that the Powerwall is likely absorbing energy on one side of the neutral and pushing out energy on the other side. This is one of the features of the Powerwall inverter - it can handle 100% phase imbalance on split-phase. Whether they are doing it through a transformer or natively in the inverters doesn't really matter to us.I suspect the voltage would increase beyond the Powerwall's limit, and the Powerwall would turn itself off (turning the grid-tie inverter with it).
So, "turning off" never really applies because it's always doing something as the micro-grid master in Backup mode.
It doesn't make any sense to use this Runtime Extender technique when the grid is up because of the compound losses incurred. This is intended to keep the Powerwall system running during an extended outage when you don't have enough solar generation to make it through the night.
