PSA: It's spelled "braking"
When $hit will hit the fan, and coup d'état begin, grammar and spelling nazis will be put against wall first.
It must be a hell of a New Years in the lawyer’s house. He woke up with that leathery mouth and dull behind-the-eyes pain that confirmed the last strawberry daiquiri was indeed a bad idea - but forged ahead nonetheless.
Today was the day. It’s a new year. People need to know. It was time to post.
He had reached his...
Braking point.
Also, rims and wheels are different things. The rim is part of a wheel, which has tires mounted upon it.
So are wings and spoilers. Wings create lift (or downforce, which is just upside down lift). Spoilers disrupt airflow that would otherwise create lift. Generally speaking with a car, if wind can go both above and below a surface that mounted on a standoff bracket, it’s a wing. If it’s on the leading or trailing edge of a surface with no space between them, it’s probably a spoiler.
Also I’m gonna object to this being the most common error on the forum, your honor. Speculative.
My data clearly shows the most common error on this forum is saying “110” or “220”, with an incidence rate approximately 50 times greater than “breaking”.
Hey don't forget Wall CHARGER. It ain't a CHARGER. Its a cord or cable that connects to the charger in the car. Right ?
And it is not a Mobile CHARGER either.
Reactions: ucmndd
