Radio upon exiting the car
Is there a setting for this?
It’s odd enough exiting the car with the stereo still playing, but this morning I opened the back door to put my dogs in their cage, stereo started. Shut the door, it stopped, open the other rear door and it starts again. Passenger gets in, yep starts again.
Is there a setting to mute stereo on exit? If not there should be :)
so just to expand on this for OP's sake - this is only true with "streaming radio" services built in to the car. it does not buffer/save your position in the song and will restart the song each time you "start" the car/interface. so if closing all doors turns off the interface, opening another one will restart the song.
if you are streaming from your device (phone), the playback will normally pause (depending on the app) once the connection has disconnected. this is true if you have headphones (BT or wired) as well.
