RE: Creating a Signature
Discussion in 'Off Topic' started by DavidP100DL, Aug 9, 2016.
Tags:
  1. DavidP100DL
    DavidP100DL P100D with P90D underline so it's faster.
    West Los Angeles
    Hi,
    I know this is lame, but I can't figure out where on this forums admin/interface where I set my "signature" that appears when I post. I feel left out not having my attached with my car details like you all.
    -V
  2. kevinf311
    kevinf311 Member
    DCish
    I feel like there might be a minimum post count before you can create a signature. At least, that's how I remember things on the old version of the site.
    Not sure if it's the same for this version.
    For me, when logged in, if I hover over the little person square in the upper right hand corner of the site "Signature" appears on the left column of the resulting popup right under "Personal Details." If you don't see this option, then post some more and maybe it will appear. Someone might know the exact number required.
  3. DavidP100DL
    West Los Angeles
    Thanks Kevin. I filled out the "About Me" in that section, but it doesn't show up when I post. So perhaps I'll need a minimum post count before it does (but I promise not to post just to find the magic number.) :D
  4. svetlana
    svetlana Member
    Vienna, VA
    Did you figure out how to do it? I was just figuring it out myself and couldn't find any box, but I see that you have your signature now!
  5. SpiceWare
    SpiceWare Member
    Fresno, Texas
    Across the top of the page, the fourth icon from the right side is your profile info. Point to it, then select Signature from the menu that shows up. I don't know if you have to have a certain number of posts to get to it.
    Alternatively, click on that icon, then select Signature from the list of options going down the left side of the page:
  6. Peters25
    Peters25 Member
    Utrecht
    Does anybody know what the number of posts are before you can add a signature and picture to your profile?
  7. DavidP100DL
    West Los Angeles
    I don't remember the exact number, but it's not as many as I thought it would be and your old post will add your signature when you finally do "unlock it."
    I think it was 5 or 10. Something on the small side.
    -V
  8. Peters25
    Peters25 Member
    Utrecht
    OK, thanks. We'll see. And I'll post here once I reach the critical number.
    ps. this is my 8th post.
  9. Peters25
    Peters25 Member
    Utrecht
    Got it. :) Eight was the number of posts.
    • Helpful x 2
  10. kevinf311
    kevinf311 Member
    DCish
    Ah ha ha!
  11. Apropos
    Apropos Member
    Seattle, WA
    Thanks, was also wondering how many it took!
  12. petergy
    petergy Member
    IL
