Talked a friend into a Performance 3. During a test drive the rep showed 3 different modes for the rear camera display. Now that she has the car, I can't find the screen to select those. They were various degrees of wide angles.
Interesting... following in case someone knows something. It’s definitelt possible to do with single camera and lens because my old Honda could display a wide angle, fisheye lens and almost top down view and pretty sure it was all software trickery.
This would definitely be pretty helpful if the image could be changed to be less distorted with wide angle. Coming from a car with no backup camera, I'm finding the back camera to be a little hard to use and makes me nervous.
I found out last night that if you are driving and turn on the rear camera that it gives you a wide-angle view. If you are in reverse it gives you a normal view.
