Recommended replacement for the rear shocks?
Discussion in 'Roadster 2008-2012' started by nick, Jan 28, 2016.
Tags:
  1. nick
    nick Member
    #1 nick, Jan 28, 2016
    One of the rear shocks has gone on my 1.5 after being replaced by Tesla 2 years ago.
    Tesla says "they have to come from Europe and we do not have an ETA".
    Any recommendations for upgrading the rear shocks?
    Car is not being raced. Spends most of its time on the freeway.
    Nick
  2. wiztecy
    wiztecy Active Member
    I wouldn't just upgrade the rear but would change all 4 of them out. Especially if they're the stock non-adjustable ones.
  3. nick
    nick Member
    Any recommendations or is the Tesla $6k upgrade kit the way to go?
  4. MLAUTO
    MLAUTO Member
    SW Florida
    I think I have some used ones if you want to go that route.
  5. hcsharp
    hcsharp Active Member
    Vermont
    The upgrade is not a bad way to go because it also includes adjustable sway bars.
  6. wiztecy
    #6 wiztecy, Jan 29, 2016
    I'm running the one way Nitrons and very happy with them. You would need to have fabricated a new drivers shock / ABS mount using your original to make them fit, but that's all.
    I personally don't think the Roadster needs to be upgraded with the adjustable sway bars. If they're cheap enough and available sure. But for $6k you could get some top of the line aftermarket shocks for sure. Actually some of the best 3-ways! I personally feel the 7-way Bilsteins are too much especially for the avg. joe. People don't even know what to do with all that nor touch it. Waist of money. Most I'd want to go is a 3-way.
    So you're running Bilsteins right now, they've been blowing out. The adjustables you're talking about from Tesla again are Bilsteins and these are also known to blow out their seals (as early as 10-15k miles in some cases), but they can be rebuilt. So the real question for you is, do you really want to go back to Bilsteins?
    If I had a $6k budget to spend on my shocks it wouldn't be with Tesla's adjustable suspension package that's for sure. If I tracked the car I'd find some way to get the rear adjustable swaybar. Front can be purchased via Blackwatch Racing. Again you don't need adjustable swaybars in my opinion for street driving if you're suspension is setup correctly unless you're auto-crossing or tracking the car. Swaybars I feel are ment to fine tune and adjust your traction between your front/rear easily. Its not ment to be your main configuration. The stock swaybars are thick enough to prevent sway/shift. Note that the Elise/Exige never came with a rear swaybar when sold stock.
  7. Andrew Wolfe
    Andrew Wolfe Roadster 472 - S 440
    Los Gatos, CA
    I have the same ones as Dennis and I am also happy with them. I think it was less than $4K total to have it done.
