Recommended tire pressure discrepancies
Why is the recommended tire pressure different between the manual, the door label and the app?!
Not the measurement, the recommended
I'm talking about the recommended. It now gets set to the pressures you have when you reset/relearn. You need to use an accurate gauge to set the pressures then relearn TPMS and the recommended values will be set. Don't be surprised if they differ from the guage by 1 or 2 PSI though.
Upvote 0
It is still recommended, but now by the owner or the tinkerer (or one and the same).
-Tesla has their multiple recommendations
-Elon has his recommendations
-MPP has their recommendations
-Other vendors have their recommendations
-Tire and wheel enthusiasts on and off here have their recommendations
(as many as the unique user ID count on here)
Upvote 0
What ever you go with, I would recommend not to exceed the you ready for this, Max pressure recommended on the tire. Ensure you account for rotating heat expansion.
Picture is an example. Resort to your tire for official max pressure.
So, what happens if you exceed this? I've always run on the high side in order to obtain the best efficiency while on the road, Then one day on our MX, started to feel funny with the steering wheel moving just a hair at slow speeds and have this vibration at speed. Found out that in the middle of one of the tires it appeared the bead was separating and the tire was ever so slightly bulging. So now, I just leave them at the recommended tire pressure.
Upvote 0
