Todd Burch
14-Year Member
Yeah that "Power" graphic shows kW going in to the battery from regen, kW going out of the battery to power the HVAC, and kW used by the motor...nothing referring to heat flow.
I don't think it would be all that complex to implement, if there was enough heat to make it worthwhile. You've already got coolant going from the motor to the battery pack, a simple temperature controlled diverter valve could send coolant to the heater core when the pack is warm enough, or to the radiator if it's too warm and heat isn't needed.Might something like you're describing be overly complex, costly or not worth the added engineering time? I know nothing about designing a car but maybe they thought of that and decided to skip it. I think it's a good idea and makes sense to me at least.
My guess is that if it's cold enough outside that you want cabin heat, that motor heat is better used keeping the batteries at temperature.
Model S has two AC systems, one for pack+motor+PEM, one for cabin. The OP's suggestion requires to couple them to transfer heat. It seems that Tesla decided against that option and that there are good reasons for that.I see a blue connection going from motor to hvac, and from hvac to batterypack
from wat I see, the heat/cold accumulated in the hvac is directed into the cabin
Yes, they can use the cabin AC compressor to help actively cool the battery and motor loops. But there's no heat exchanger (heater core) to blow drivetrain heat into the cabin, at least how I understood it.Actually a Tesla engineer told me they could cross-connect the HVAC systems.
Imagine that the car is parked at a ski area for the day, and it's 15deg F outside. Wouldn't the car consume a fair amount of power just sitting there?
