Hi,
Not Telsa related but I need to relocate a solar breaker (Combiner/gateway box?) 2ft over to be able to install my 400A panel. Solar panels have Enphase microinverters and supposedly have a 25yr warranty. The electricians I've been getting estimates for the panel upgrade for mostly say they can move the box for me but I should ask the solar company that installed it whether it would void the warranty if somone else does it.
The solar company that installed my panels said it would cost $1,300-1,400 to relocate the box. They have a $699 minimum service charge and would most likely require 2 trips (one for the removal, one to reconnect back to the new panel. Isn't the price a bit steep? I pad a little over $13k for 4kw system 3 years ago (so I still have a long way before warranty expires.
My questions are...
1) Does the original installer also need to be the one to relocate the solar box or can any solar installer do it so as to maintain the warranty? Isn't the 25 years warranty a manufacturer's warranty? I believe the 25 year warranty has to do with the performance of the panels (ie degradation/efficiency). Do I need to contact the manufacturer and ask?
2) What's the likelihood that disconnecting and relocating the solar box would cause a failure to the solar panel system, especially if each panel have microinverters? I thought the benefit of microinverters is I could simply replace the ones that are broken without affecting the other panels.
3) Since the entire cost of the system was $13k before tax credit, is it worth paying $1,300-1,400 to move it. Or should one just have an electrician do it since it seems like a pretty straightforward job.
4) What's the worst that could go wrong if it wasn't reinstalled correctly? Does it require any reprogramming after relocation? The solar box is also the brains of the solar panel system right? I'm thinking of it like a desktop pc, I can easily unplug it and move it to another location without any issue as long as I don't drop it
Thoughts? Suggestions?
My questions are...
![Grinning face :grinning: 😀](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
