Hi Everyone, I currently have what will be 27kw of solar between my roof and back yard. It was EXTREMELY challenging getting San Diego to approve this much solar, because you have to "prove" that you will use it and aren't building solar for the sole purpose of selling it back to the grid. My long term plan is to convert everything to electrical - house heat converted to heat pump, pool heater already converted to heat pump, gas stove converted to electric, etc.
When you remove the high draw devices I use about 20-30 kwh / day. My pool pump alone is an additional 13.6 kwh/day, plus an additional 43 kwh/day for the pool heater (6 out of 12 months per year), 10 kwh for home AC 6 months out of year, anyway I can go on but if I cut out high draw devices I had pretty reasonable draw, but if I want to, I go easily go up to >200kwh/day.
I completely understand that running the highdraws off batteries would be prohibitively expensive. However, I want to be able to use my high draw devices direct from solar in the event of a power failure, as I want to eventually transition to off grid. What I cannot seem to determine is, if I have lets say 2 powerwalls, and the power goes out, am I limited to the 10kw max output of the two powerwalls, or will I still have access to the full 26kw of power my solar array is producing during daylight hours? Ideally I'd like to run the heat pumps and pool pumps directly off the solar inverters from 10am-3pm, and then off hours switch them off and run from powerwalls/lingering solar the rest of the day. Obviously when the grid is up this is irrelevant because the full output from the solar goes into your electrical panel.
It was suggested that I simply make these high draw devices on their own off grid circuit, but that means It would be impossible for me to use grid power with them in the winter months.
Thanks!
Thanks!
