Apologies for the noob question, I haven't found a definitive answer on the forum.
I'm playing with ABRP, and looking at trips in remote areas with no SC coverage, but it keeps coming back with "no plan found".
I can see chargers in this area on plugshare... What's a good way to plan a route in such situations?
Don't have the car yet, but planning on M3 LR RWD.
Thanks
ABRP is still a good planner but when it can't plan a route (or routes way out of the way because there are no direct superchargers) you can add suggestions to it to work out a route.
While ABRP doesn't plan using normal chargers, it still shows them on the map (at least the ones listed on openchargemap).
If it fails to plan a route or takes a long way, take an overall look at ABRP's map looking at superchargers in your general route. If there's a section or sections of road without one, then zoom in along the general route you want to go looking for other chargers.
Pick a likely spot with a charger you might like to stop for a sightseeing, lunch, or supper break, right click it and "Add as waypoint" and drag it on the list in the order where it would be in your route (in the middle somewhere). Click the gear next to it, select the charging power if it isn't automatically populated (or use 6.2 kW for a reasonable 30A/208V charger in a commercial location) and select a 04:00 hour charge time (or as long as you are willing to wait).
Repeat for any known overnight hotel or campground stays with a charger, but instead of specifying charge time, you can specify a waypoint depart at time for the time you leave the next morning.
Then plan the route again. Then when the route comes up, you can see how much charge you have at the next stop from your forced stops and you can reduce the 04:00 hour charge accordingly.
If you specify a depart time on your initial departure point, you will see each stop with the time of day you arrive and depart it too, which can further help out when you want to take your lunch or supper breaks.
