I had started digging in to that vega curve concept recently, as I’ve watched it play out when I had the -CCs be closer in expiry than purchased leaps at lower strikes. It was maddening to see near term -CC with lower deltas run up against me while the leaps weren’t moving anywhere near as quickly.You can always close the -C's and reopen cash covered puts at net-zero $. That would reduce ∆ exposure but probably wouldn't do much for time decay, since you're so far out in expiry.
Potentially more useful, consider the value of all the -C's as a collective number. Consider breaking off a small number of contracts (like 5% of the total # of contracts) and roll them/it to a close expiration and reasonable strike such that you can expire that single contract. To enable this, roll the rest of the contracts out/up to accomodate.
Say you do that by bringing in one of 20 CCs. At the end of a few weeks or a month or whatever it takes to expire that one contract you're left with 2000 shares but only 19 -C's. So then you split the 19 -C's into one expire-able contract plus a new [ostensibly less favorable] strike/expiry set of 19 contracts. And so on. Over time you may be able to reduce the number of unfavorable rolls required to get one expire-able contract per cycle.
Another alternative--and mind that I haven't fully vetted this concept so its worth doing your own diligence--but you can move around contracts based on where we are on the volatility spectrum. In general, the closer the expiration, the better Vega/$. And in general, the higher the strike, the better Vega/$. So, theoretically, you would move the lot of -C's around (and this can be in conjunction with the 1 for 19 concept above) based on whether volatility is high or low. If volatility spikes, you'd want to find a strike/expiry combo that is as close and as high as possible, as that will burn off the most volatility. Then if volatility dips you roll to a strike/expiry combo that's as far and as low as possible, wait for volatility climb up again, and then roll back to close/high.
***I think. Happy for a logic check on that one...
I do like the idea of moving some of the contracts more aggressively. The concept of uncovering some of the lots of shares (so as to be able to start selling nearer term credits again for instance) is interesting.
